Is there a “random” command within the maestro scripting functionality?
thanks
thanks
Unfortunately, Maestro scripting does not have a random command. However, you might be able to use the GET_MS
and MOD
commands together in a Maestro script to get a random number within a certain range, which is probably the easiest method to implement.
You can also see our response here for other alternatives on generating random numbers using the Maestro scripting language.
