Maestro PWM or alternative
Is there any way to get a single pulse width from the maestro? I want to use sensors that return a pulse width. I know I could use voltage on most but I prefer pulse width. Servo channels won’t work because they won’t send 0 or just 1 pulse. Using the SERVO setting of 0 disables the channel so I can’t get to the previous pulse width.
Maestro would have been best because I have servo’s and sensors that are near each other and the Maestro is much smaller than the UNO with a large USB connect. If maestro can’t return a pulse width, are there any alternatives that support this that will drive servo’s (or in worst case allows pulse width?
Thanks, Jon.
A post was merged into an existing topic: Pwm on all maestro channels
