Okay this one has got me stumped I have spent a better part of a day trying to get my script to work on multiply servos to no avail. I can run servo 0 no problem it does exactly what I want it to do. I need to run 6 servos using the the same script 0-5. Any help would be greatly appreciated
200
begin dup while
3oclock
1oclock1
12oclock1
11oclock
10oclock
11oclock
12oclock2
1oclock2
all_frames
1 minus
repeat
sub 3oclock # was 99-96 ms
99 96 99 96 99 96 99 96
all_frames
return
sub 1oclock1 #was 80-77 ms
80 77 80 77 80 77 80 77
all_frames
return
sub 1oclock2 #was 80-77 ms
77 80 77 80 77 80 77 80
all_frames
return
sub 12oclock1 #full extension counterclockwise 55-65 ms
55 65
all_frames
return
sub 12oclock2 #full extension counterclockwise 55-65 ms
70 65
all_frames
return
sub 11oclock
37 40 37 40 37 40 37 40
all_frames
return
sub 10oclock
20 23 20 23 20 23 20 23
all_frames
return
#begin
#neutral
#drop
#quit
#repeat
#sub frame_1 #slow speed
#10 1 acceleration
#100 1 speed
#100 times # times the servo positioning
#1 servo
#1 delay_seconds
#moving_wait
#return
#sub frame_2
#8 1 acceleration
#80 1 speed
#1000 times
#1 servo
#3 delay_seconds
#moving_wait
#return
#sub delay_seconds
#begin dup while # check if the count has reached zero
#1 minus 1000 delay # subtract one and delay 1s
#repeat
#drop return # remove the 0 from the stack and return
sub moving_wait
begin
get_moving_state
while
# wait until it is no longer moving
repeat
return
sub neutral
6000 1 servo
return
sub all_frames
begin depth
1 greater_than
while
servo0
repeat
return
sub servo0
5 1 acceleration
60 1 speed
100 times
0 servo
200 delay
moving_wait
return
sub servo1
5 1 acceleration
60 1 speed
100 times
1 servo
200 delay
moving_wait
return
sub servo2
5 1 acceleration
60 1 speed
100 times
2 servo
200 delay
moving_wait
return
sub servo3
5 1 acceleration
60 1 speed
100 times
3 servo
200 delay
moving_wait
return
sub servo4
5 1 acceleration
60 1 speed
100 times
4 servo
200 delay
moving_wait
return
sub servo5
5 1 acceleration
60 1 speed
100 times
5 servo
200 delay
moving_wait
return
It is not entirely clear to me how you want your code to work, but it looks like right now your all_frames
subroutine simply calls your servo0
subroutine in a loop until the stack is left with only 1 value, so your other servo#
subroutines never get called.
I suspect you want the servo#
subroutines to get called in turn, but it looks like you are always either putting 8 numbers or 2 numbers on the stack before calling all_frames
, and you didn’t describe how you want those values to be used with 6 servos. If my observation above does not help get you on the right track, could you explain in more detail what you want to happen with the values on stack when you call all_frames
HI Brandon
I would like to have the sub all_frames call all the servos to run all the previous subs at the same time. I have written before the all_frames sub. I have tried writing as follow bellow but isnt working correctly it will do 1 of the 2 number associated with each servo.
Thanks
Too Tall
sub all_frames
begin depth
1 greater_than
while
servo0
servo1
servo2
servo3
servo4
repeat
return
As I mentioned before, it looks like you are putting 8 or 2 numbers on the stack before calling all_frames
, but it is not set to handle either of those cases. In the modified all_frames
subroutine you posted, if you only want the while
loop to run through once, it can only support 5 values (one for each of your servo#
subroutines.
It is not clear to me what you want each of the values you are putting on the stack to do, since you have 8 of them, but only 6 servos. Could you explain in detail what you want each of the values you are putting on the stack to do? For example, what do you want to happen when you call your 3oclock
subroutine (copied below for reference)?
all_frames
return
And what do you want it to do when you instead only put 2 values on the stack, such as with your 12oclock1
subroutine?
55 65
all_frames
return
the 12oclock and 3oclock etc subframes are the positions that I want all the servo to travel to simultaneously I am trying to get the all_frames to do is basically clone servo0 to the remaining servos (1-5) because I want all 6 servos to run the exact same routine in a loop. Hope that has clarified what I am trying to do.
Update
I took a moment and rewrote the entire script and I am now getting the desired response out of all six servos. If you could take a second and see if there is some other way to write it to reduce the size I would be much appreciated.
200
begin dup while
3oclock
1oclock1
12oclock1
11oclock
10oclock
11oclock
12oclock2
1oclock2
1 minus
repeat
sub 3oclock #9900-9600 ms
99 servo0 99 servo1 99 servo2 99 servo3 99 servo4 99 servo5
96 servo0 96 servo1 96 servo2 96 servo3 96 servo4 96 servo5
moving_wait
return
sub 1oclock1 #8000-7700 ms
80 servo0 80 servo1 80 servo2 80 servo3 80 servo4 80 servo5
77 servo0 77 servo1 77 servo2 77 servo3 77 servo4 77 servo5
moving_wait
return
sub 1oclock2 #8000-7700 ms
moving_wait
return
55 servo0 55 servo1 55 servo2 55 servo3 55 servo4 55 servo5
65 servo0 65 servo1 65 servo2 65 servo3 65 servo4 65 servo5
moving_wait
return
70 servo0 70 servo1 70 servo2 70 servo3 70 servo4 70 servo5
moving_wait
return
sub 11oclock
37 servo0 37 servo1 37 servo2 37 servo3 37 servo4 37 servo5
40 servo0 40 servo1 40 servo2 40 servo3 40 servo4 40 servo5
moving_wait
return
sub 10oclock
20 servo0 20 servo1 20 servo2 20 servo3 20 servo4 20 servo5
23 servo0 23 servo1 23 servo2 23 servo3 23 servo4 23 servo5
moving_wait
return
#begin
#neutral
#drop
#quit
#repeat
sub moving_wait
begin
get_moving_state
while
repeat
return
sub neutral
6000 1 servo
return
sub servo0
5 0 acceleration
60 0 speed
100 times
0 servo
200 delay
return
sub servo1
5 1 acceleration
60 1 speed
100 times
1 servo
200 delay
return
sub servo2
5 2 acceleration
60 2 speed
100 times
2 servo
200 delay
return
sub servo3
5 3 acceleration
60 3 speed
100 times
3 servo
200 delay
return
sub servo4
5 4 acceleration
60 4 speed
100 times
4 servo
200 delay
return
sub servo5
5 5 acceleration
60 5 speed
100 times
5 servo
200 delay
return
Thanks
Too Tall
I am glad to hear you got it working how you wanted!
There are probably a lot of ways you could make it simpler and reduce the size of the script. The main thing to look for is when code is repeated and if you can better utilize subroutines instead, or if code is repeated that does not need to be.
For example, it does not look like you are changing the speed and acceleration settings throughout the script, so you could just configure the desired settings in the “Channel Settings” tab, and the Maestro will use those when it boots up. If you want it in the script for redundancy, you could still remove the speed
and acceleration
commands from your individual subroutines and just set the speed and acceleration to the beginning of your script (before your main loop), like this:
#set the speed and acceleration of all 6 servos to 60 and 5 respectively
0 begin dup 6 less_than while
dup dup
60 swap speed
5 swap acceleration
1 plus
repeat
drop
begin
# main loop
repeat
Additionally, since you want to use the same position for all of your servos, you can have a single subroutine that takes the target position and applies it to all of the servo channels, instead of having a separate subroutine for each channel. For example, something like this:
sub set_servos
100 times
over over servo
1 plus
#200 delay
repeat
moving_wait
drop drop
return
So, 60 set_servos
will set the target position of all 6 servo channels to 6000 quarter-microseconds. In your updated script, there is still a 200 ms delay between setting the position of each servo. If you really want that delay instead of setting them all at the same time like you described, then you can uncomment the 200 delay
line of code by removing the #
Using that set_servos
subroutine will allow you to simplify your other subroutines. For example, 3oclock
would look like this:
sub 3oclock
99 set_servos
96 set_servos
return
