Hey ,
i tried to control servo with the following program :
#include <fcntl.h>
#include <stdlib.h>
#include <stdio.h>
#include <termios.h>
#define DEBUG 1
void openPort(int * fd);
void setBaudRate(int * fd);
void maestroGetPosition(int * fd , unsigned char channel , unsigned short * position);
void maestroSetTarget(int *port, unsigned char channel, unsigned short target);
void closePort(int *fd);
int main(){
int mainFd , channel=0;
unsigned short target=7000, position=0;
openPort(&mainFd);
setBaudRate(&mainFd);
maestroGetPosition(&mainFd,channel,&position);
maestroSetTarget(&mainFd,channel,target);
exit(0);
/* Open the Maestro's serial port. */
void openPort(int * fd){
*fd=open("/dev/ACM1",O_RDWR | O_NOCTTY | O_NDELAY);
if(0>fd){
printf("Cannot open /dev/ACM1 :/\n");
exit(1);
#if DEBUG
printf("Port open successfully :)\n");
#endif
/* Choose the baud rate (bits per second).*/
void setBaudRate(int * fd){
struct termios options;
// Get the current settings of the serial port.
tcgetattr (*fd, &options);
// Set the read and write speed to 19200 BAUD.
// All speeds can be prefixed with B as a settings.
cfsetispeed (&options, B9600);
cfsetospeed (&options, B9600);
// Now to set the other settings. Here we use the no parity example. Both will assumme 8-bit words.
// PARENB is enabled parity bit. This disables the parity bit.
options.c_cflag &= ~PARENB;
// CSTOPB means 2 stop bits, otherwise (in this case) only one stop bit.
options.c_cflag &= ~CSTOPB;
// CSIZE is a mask for all the data size bits, so anding with the negation clears out the current data size setting.
options.c_cflag &= ~CSIZE;
// CS8 means 8-bits per work
options.c_cflag |= CS8;
/** Implements the Maestro's Get Position serial command.
* channel: Channel number from 0 to 23
* position: A pointer to the returned position value (for a servo channel, the units are quarter-milliseconds)
* Returns 1 on success, 0 on failure.
* For more information on this command, see the "Serial Servo Commands"
* section of the Maestro User's Guide: https://www.pololu.com/docs/0J40 */
void maestroGetPosition(int * fd , unsigned char channel , unsigned short * position){
int ret=0;
unsigned char command[2];
unsigned char response[2];
// Compose the command.
command[0] = 0x90;
command[1] = channel;
// Send the command to the device.
ret=write(*fd,command,2);
printf("maestroGetPosition , write %d\n",ret);
// Read the response from the device.
ret=read(*fd,response,2);
printf("maestroGetPosition , read %d\n",ret);
// Convert the bytes received in to a position.
*position = response[0] + 256*response[1];
printf("Current position is %d.\n", *position);
/** Implements the Maestro's Set Target serial command.
* target: The target value (for a servo channel, the units are quarter-milliseconds)
* Fore more information on this command, see the "Serial Servo Commands"
void maestroSetTarget(int * fd, unsigned char channel, unsigned short target){
int ret=0;
unsigned char command[4];
command[0] = 0x84;
command[2] = target & 0x7F;
command[3] = (target >> 7) & 0x7F;
ret=write(*fd,command,4);
/* Closing the Maestro's serial port. */
void closePort(int *fd){
close(*fd);
it doesn’t work for me , can u see any problem ?
thanks for the help …
