Hi All,
Just received my Maestro 6-Channel controller and I am trying to work out a script to switch 3 servos with 3 independent switches. I am trying to use these three servos to open and close three “butterflies” in a vent tube. This will either allow or deny air flow through the tube.
The setup I am trying to implement is :-
Switch 1 (off=0V / ON=5V) controls servo 1 (off=1ms / on= 2ms - approx. 180 degree swing)
Switch 2 (off=0V / ON=5V) controls servo 2 (off=1ms / on= 2ms - approx. 180 degree swing)
Switch 3 (off=0V / ON=5V) controls servo 3 (off=1ms / on= 2ms - approx. 180 degree swing)
My wiring configuration is :-
Servo 1 is set as a servo on channel 0
Servo 2 is set as a servo on channel 1
Servo 3 is set as a servo on channel 2
Switch 1 is set as an input on channel 3
Switch 2 is set as an input on channel 4
Switch 3 is set as an input on channel 5
I have tried modifying the example code from the user manual (the three switch example) but I’m afraid that my scripting knowledge is very poor and I do not appear to be able to get anything working. I am not bothered about acceleration or speed so I have left these set to zero.
Has anyone done anything like this that can offer some example script code, or even some help
Many thanks…
Ian
