My continious servo needs to turn 720 degrees and stop. This works fine until i send thr framed to script. After applying settings and disconnecting the usb, the battery is connected and the script runs in a continious loop. How can i get script to stop after 720 degrees? The program runs a loop, never stopping.
It sounds like you might have copied a sequence into a script using the “Copy Sequence to Script” button in the Maestro Control Center. If this is the case and you want the script to only run once when you power up the Maestro, you should be able to go to the “Script” tab in the Maestro Control Center and add the quit
command before repeat
in your script.
If this does not work or you have additional problems or questions, you can post your modified script here, and I would be glad to take a look.
-Brandon
Brandon,
Thank you, thank you, thank you !!!
Your answer saved me hours of downtime. And i really appreciate
the fast response.
