Hi
I am using 6 channel Masetro in windows 10 and I am writing a C code to use this board. I am using the library provided with example by maestro.
When I test it with example it says unable to open the port. when I tried to find the port number its connected I am unable to find it as my windows 10 is showing under the Polulu USB Device and I am unable to find its com port number.
i have configured my board in DUAL USB mode.
Please help to get over it
Regards
I moved your topic to the “Servo controllers and servos” section since that is more appropriate.
You should be able to find the COM port numbers of your Maestro by looking in the “Ports (COM & LPT)” section of the Device Manager. If you cannot find them there, please post a screenshot of your Device Manager after opening the “Pololu USB Devices”, “Ports (COM & LPT)”, and “Other Devices” sections.
