Hello pololulu forum. I’ve been testing my new m3pi line follower but have run into a few issues with regard to the detected line position. When i run the pre made line following and pid programs the robot runs perfectly fine. However when i created my own program that simply prints out the line position onto the lcd i keep getting weird values in the range of 0-50000 instead of the expected value between 0-4000. I’m programming on the mbed lpc microprocessor and suspect that the sensor values aren’t being transfered propery through the serial communication. Do you have any ideas why this is happening?
Note: I created my own intline_position function which has the same exact code at the line_position function except it returns an integer and doesn’t convert the acquired data packet into floating point. Either way neither my function nor the line_position function return appropriate values. The line_position function should return values between -1 and 1 but ends up showing floating point values like 15.0 and my function ends up showing integer like 50,000 instead of values between 0 and 4000
#include "mbed.h"
#include "m3pi.h"
m3pi m3pi;
int main() {
int intpos = 0;
m3pi.locate(0,0);
m3pi.printf("Wait");
wait(5);
m3pi.cls();
m3pi.printf("Go!");
m3pi.sensor_auto_calibrate();
int i = 0;
while(1) {
intpos = m3pi.intline_position();
float position_of_line = m3pi.line_position();
if(i==1000)
m3pi.cls();
m3pi.locate(0,0);
m3pi.printf("%7.1f",position_of_line);
m3pi.locate(0,1);
m3pi.printf("%7d",intpos);
i=0;
i++;
