This is my first project using an IMU and I don’t know what I am doing wrong.
I have a Romi 32U4 with the built-in LSM6DS33 and an onboard Raspberry Pi using I2C. The standard pololu-rpi-slave-arduino-library is installed on the 32U4.
When it is sitting still I would expect the gyro values to not change or at least have minimal changes and the accelerometer values to be zero. When it is moving, I would expect all the values to change appropriate to the motion. Instead, when it is sitting still the gyro values change wildly and constantly, and when it is moving the accelerometer values remain zero.
Here is my python code to setup the LSM6 and read the IMU values from the Raspberry Pi
import struct
import time
from smbus2 import SMBus
IMU_ADRS1 = 0x6b
CTRL1_XL = 0x10
CTRL2_G = 0x11
CTRL3_C = 0x12
CTRL4_C = 0x13
CTRL5_C = 0x14
CTRL6_C = 0x15
CTRL7_G = 0x16
OUTX_L_G = 0x22
XL_HM_MODE_MASK = 0b00010000
GY_HM_MODE_MASK = 0b10000000
ODR_MASK = 0b11110000
ODR_OFF = 0b00000000
ODR_166KHZ = 0b10000000
class IMUData:
def __init__(self, tup):
self.gy_x, self.gy_y, self.gy_z, self.xl_x, self.xl_y, self.xl_z = tup
def __repr__(self):
return f"IMUData(gy_x:{self.gy_x}, gy_y:{self.gy_y}, gy_z:{self.gy_z}, xl_x:{self.xl_x}, xl_y:{self.xl_y}, xl_z:{self.xl_z})"
class LSM6:
def __init__(self, bus, adrs=IMU_ADRS1, xl_odr=ODR_OFF, xl_hp=False, gy_odr=ODR_OFF, gy_hp=False):
self.bus = bus
self.adrs = adrs
self.xl_odr = xl_odr
self.xl_hp = xl_hp
self.gy_odr = gy_odr
self.gy_hp = gy_hp
@property
def xl_odr(self):
return read_byte_with_mask(self.bus, self.adrs, CTRL1_XL, ODR_MASK)
@xl_odr.setter
def xl_odr(self, value):
write_byte_with_mask(self.bus, self.adrs, CTRL1_XL, value, ODR_MASK)
@property
def xl_hp(self):
return read_byte_with_mask(self.bus, self.adrs, CTRL6_C, XL_HM_MODE_MASK) != 0
@xl_hp.setter
def xl_hp(self, value):
write_byte_with_mask(self.bus, self.adrs, CTRL6_C, (1 if value else 0) << 4, XL_HM_MODE_MASK)
@property
def gy_odr(self):
return read_byte_with_mask(self.bus, self.adrs, CTRL2_G, ODR_MASK)
@gy_odr.setter
def gy_odr(self, value):
write_byte_with_mask(self.bus, self.adrs, CTRL2_G, value, ODR_MASK)
@property
def gy_hp(self):
return read_byte_with_mask(self.bus, self.adrs, CTRL7_G, GY_HM_MODE_MASK) != 0
@gy_hp.setter
def gy_hp(self, value):
write_byte_with_mask(self.bus, self.adrs, CTRL7_G, (1 if value else 0) << 7, GY_HM_MODE_MASK)
@property
def imu_data(self):
t = read_unpack(self.bus, self.adrs, OUTX_L_G, 12, "HHHHHH")
return IMUData(t)
def read_unpack(bus, adrs, register, size, fmt):
bus.write_byte(adrs, register) # no value, just moves the pointer to the specified address
time.sleep(0.0001) # pause to give the bus time to catch up
byte_list = [bus.read_byte(adrs) for _ in range(size)]
return struct.unpack(fmt, bytes(byte_list))
def write_pack(bus, adrs, register, fmt, *data):
data_array = list(struct.pack(fmt, *data))
bus.write_i2c_block_data(adrs, register, data_array)
def read_byte_with_mask(bus, adrs, reg, mask):
return read_unpack(bus, adrs, reg, 1, "B")[0] & mask
def write_byte_with_mask(bus, adrs, reg, value, mask):
r = read_unpack(bus, adrs, reg, 1, "B")[0]
b = (r & ~mask) | (value & mask)
write_pack(bus, adrs, reg, "B", b)
def main():
bus = SMBus(1)
lsm = LSM6(bus, IMU_ADRS1, ODR_166KHZ, True, ODR_166KHZ, True)
while True:
print(lsm.imu_data)
time.sleep(1)
if __name__ == "__main__":
main()
