I’m using a LSM6DS33 and I am getting really weird numbers for the acceleration and angular velocity. It is really large when it still. I use the LSM303 library.
Here is example data (this is the average of points) when the sensor is still
linear acceleration data at ±8g (mm/s^2): x: 265.69 y:126.86 z:10201.69
angular velocity for 2000dps (mdps): x: 3920.00 y:-5950.00 z: -2520.00
I changed the scales and it only changes the variation. I’m very confused by the large Z acceleration. Is that just the IMU being aware of gravity?
Here is my code:
#include <ros.h>
#include <ros/time.h>
#include <geometry_msgs/Twist.h> //Add the message types
#include <geometry_msgs/Pose.h>
#include <geometry_msgs/Vector3.h>
#include <std_msgs/Float32.h>
#include <sensor_msgs/Imu.h>
#include <LIS3MDL.h>
#include <LSM6.h>
#include <Wire.h>
#include <math.h>
const float gravity = 9.81; //Gravity in m/s^2
const float accGain = 0.244; //mg/LSB from dataSheet for +-8g
//const float accGain = 0.061; //mg/LSB from dataSheet for +- 2g
const float gyroGain = 70; //mdps/LSB from dataSheet for 2000dps max
//const float gyroGain = 8.75; //mdps/LSB from dataSheet for 245dps max
//const float magGain = 6842.0; //LSB/gauss
const float magGain = 1711.0; //LSB/gauss
const float xmin = -676;
void setup() {
Wire.begin(); //Initialize I2C
// Make sure the sensors get initialized
if (!acc_gyr.init())
//Turn on imu_LED
digitalWrite(imu_LED, HIGH);
while (1);
}//end if
acc_gyr.enableDefault();
acc_gyr.writeReg(LSM6::CTRL1_XL, 0x3C); // 52 Hz, 8 g full scale
acc_gyr.writeReg(LSM6::CTRL2_G, 0x4C); // 104 Hz, 2000 dps full scale
if (!mag.init())
//Turn on mag_LED
digitalWrite(mag_LED, HIGH);
while (1);
}//end if
mag.enableDefault();
mag.writeReg(LIS3MDL::CTRL_REG2, 0x60); //
delay(1000);
analogWrite(LED, 127); //Turn on good status LED
digitalWrite(13, LOW); //Turn off initialization LED
time_0 = millis(); //Initial Time
theta = 0;
prevV = 0;
coilTime_0 = millis();//Initial Time for the coils
analogWriteFrequency(22, 5000); //changes the PWM frequency of FTM0 pins (22, 23) to 3000 Hz
analogWriteFrequency(4, 5000);
Serial.begin(9600);
}//end setup
void loop() {
// put your main code here, to run repeatedly:
//Read IMU Data
mag.read(); //get data from the magnetometer
acc_gyr.readAcc(); //get data from the accelerometer
acc_gyr.readGyro(); //get data from the accelerometer and gyro
//Assign values to the magnet
magnetApplied.x = (mag.m.x - xoff) * magScale_X / magGain*100;
magnetApplied.y = (mag.m.y - yoff) * magScale_Y / magGain*100;
magnetApplied.z = (mag.m.z - zoff) * magScale_Z / magGain*100;
IMU.header.frame_id = "IMU"; // Give the Sensor an ID
IMU.header.stamp = nh.now(); // This is NEEDED TO GET A TIME STEP
//Assign values to the accelerometer
IMU.linear_acceleration.x = acc_gyr.a.x * accGain * gravity;
IMU.linear_acceleration.y = acc_gyr.a.y * accGain * gravity;
IMU.linear_acceleration.z = acc_gyr.a.z * accGain * gravity;
//Assign values to the gyro
IMU.angular_velocity.x = acc_gyr.g.x * gyroGain;
IMU.angular_velocity.y = acc_gyr.g.y * gyroGain;
IMU.angular_velocity.z = acc_gyr.g.z * gyroGain;
delay(10);
}//end loop
Any ideas of how to fix this or how to continue to troubleshoot?
Thanks for your support,
CW
