I have several Pololu LSM303DLHC Carrier Boards (Item #2124).
When any of this board lying still on the table (in any orientation but without motion), there exists value’s jitter (approx. plus-minus 5 LSB units) on any of three axis of accelerometer.
There are no vibrating objects on this table and around it.
The Acc registers settings are:
REG1_A (20h) = 47h
REG2_A (21h) = 00h
REG4_A (23h) = 88h
The other registers are default (not initialised in code).
This effect is found when reading 6-bytes portions with a 10-ms period, 32 (or any) times successively.
I2C bus speed (400 or 100 kHz) is not affected.
Due to LSM303DLHC’s 50 Hz ODR and 100Hz reading I see sometimes a pair of the same value and a jitter values like this:
927
927
921
928
925
925
923
(on any axis, at any value jitter is within 10 LSB units)
There are no errors reports on I2C bus, sygnal integrity looks fine on oscilloscope (levels, rise & fall times etc.)
Uin and U I/O = 3.3V.
Is such value’s jitter a LSM303DLHC’s parameter (i.e. G-sensor accuracy or digital noise)?
If not, can I eliminate it?
