Hello all building on from my other post
Im modifying the example arduino heading sketch to display an average heading say over two minutes
the code compiles and loads, the output im getting on say a heading of 80` is an average heading of 30
Id expect the av reading to also be around 80.
can any one tell me whats going on here and where im going wrong Im sure its very basic stuff
Ive commented //KenB to indicate what code has been pasted in to the example
#include <Wire.h>
#include <LSM303DLH.h>
LSM303DLH compass;
const int numReadings = 60; // this value determines the size of the readings array KenB
int readings[numReadings]; // this declares the array to hold the readings from the compass KenB
int index = 0; // the index of the current reading KenB
int total = 0; // the running total KenB
int average = 0; // the average KenB
void setup() {
Serial.begin(9600);
// initialize all the readings to 0: KenB
for (int thisReading = 0; thisReading < numReadings; thisReading++) //KenB
readings[thisReading] = 0; //KenB
Wire.begin();
compass.enableDefault();
// Calibration values. Use the Calibrate example program to get the values for
// your compass.
compass.m_min.x = -520; compass.m_min.y = -570; compass.m_min.z = -770;
compass.m_max.x = +540; compass.m_max.y = +500; compass.m_max.z = 180;
void loop() {
compass.read();
int heading = compass.heading((LSM303DLH::vector){0,-1,0});
Serial.println(heading);
delay(1000);
// subtract the last reading: KenB
total= total - readings[index]; // KenB
// read from the sensor: // KenB
readings[index] = (heading); // KenB
// add the reading to the total: // KenB
total= total + readings[index]; // KenB
// advance to the next position in the array: // KenB
index = index + 1; // KenB
// if we're at the end of the array... KenB
if (index >= numReadings) // KenB
// ...wrap around to the beginning: KenB
index = 0; // KenB
// calculate the average: KenB
average = total / numReadings; // KenB
// send it to the computer as ASCII digits // KenB
Serial.println(average); // KenB
Ive made a slight mod to make it clearer in the display on the serial monitor
and on reexamination of the output it looks like im actually getting the expected out put
the average is matching the heading its just taking some time to update.
Im I missing something here
It sounds like you changed something but did not post the updated code. If you want help, you really need to post what the version you are using, and describe precisely what it is doing differently from what you expect.
heres the updated code Ive made further changes .im using the Arduino version 0022 on arduino uno
ive successfully got a current heading and an average reading with an array which takes about 10 sec to display the up date when i rotate the compass.
which is fine for my needs .taking this further ive declared a second array that contains 60 elements
to get an average over a longer time period
the output to the serial monitor looks like this:
compass heading :
101
average heading : //after movement of the compass about 10 sec after
101
big Average heading : // about 30 sec after it equals compass heading
101
compass heading :
101
avarage heading :
101
big Avarage // about 40 sec after it is greater than compass heading and continues to increment
164
the idea is to have two sampling rates by having two different sized containers but what happens is that
the larger container does not settle at the same heading reading it continues to increment
not sure why or how to proceed
heres the code
#include <Wire.h>
LSM303DLH compass;
const int numReadings = 10; // this value determines the size of the readings array KenB
const int bigReadings = 30;
int bigreadings[bigReadings];
int bigindex = 0;
int bigtotal = 0;
int bigaverage = 0;
void setup() {
Serial.begin(9600);
//for
//(int bigReading = 0; bigReading < bigReadings; bigReading++)
//bigreadings[bigReading] = 0; //KenB
Wire.begin();
// your compass.
void loop() {
compass.read();
Serial.println("heading");
delay(1000);
for
index = index + 1;
index = 0;
Serial.println("av 10 sec");
bigtotal= bigtotal - bigreadings[bigindex];
bigreadings[bigindex] = (heading);
bigtotal= bigtotal + bigreadings[bigindex];
bigindex = bigindex + 1;
if (bigindex >= bigReadings)
bigindex = 0;
bigaverage = bigtotal / bigReadings;
Serial.println("big av 30 sec");
Serial.println(bigaverage);
It’s really hard to help you, because you are presenting a program that is more complicated than necessary and not telling me exactly what is going wrong.
You should do the following:
Simplify your program by removing every line that is unnecessary to demonstrate the problem. Specifically: remove all commented-out lines of code. If your small average works, remove it. Remove the compass code and replace it with a constant simulated heading of 100. And so on.
If you are still having trouble, post the code again along with the actual output that you get on the serial terminal. Hand-typing something similar to the output is a waste of time and is unlikely to be as useful as the actual output.
