I am a student at university and I have a project for my lesson.
I would like to get the acceleration data in the X, Y and Z axes from the LMS303D accelerometer sensor using SPI Communication. I am using the MSP430G2553 microcontroller for this. But I have a problem, I can not get the acceleration data from the LSM303D.Can you help me with how to do it? The data I get from the LSM303D is only 255
My code for MSPG2553:
#include "io430.h"
unsigned int write_reg(unsigned char );
void konfigurasyon( unsigned char ,unsigned char );
void spi_init(void);
void spi_init(void)
P1OUT |= BIT4;
P1DIR |= BIT4;
P1SEL = BIT7 | BIT6 | BIT5;
P1SEL2 = BIT7 | BIT6 | BIT5;
UCB0CTL1 = UCSWRST;
UCB0CTL0 |= UCCKPH + UCMSB + UCMST + UCSYNC; // 3-pin, 8-bit SPI master
UCB0CTL1 |= UCSSEL1;// + ID_1; // SMCLK
UCB0BR0 |= 0x02; // /2
UCB0BR1 = 0; //
// UCB0CTL0 = 0; // No modulation
UCB0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
// IE2 |= UCA0RXIE; // Enable USCI0 RX interrupt
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
unsigned int in[6]={0x00,0x00,0x00,0x00,0x00,0x00};
spi_init();
konfigurasyon(0x21,0x00); //CTRL2
konfigurasyon(0x20,0x57); //CTRl 1
while(1)
in[0]=write_reg(0x28);
in[1]=write_reg(0x29);
in[2]=write_reg(0x2A);
in[3]=write_reg(0x2B);
in[4]=write_reg(0x2C);
in[5]=write_reg(0x2D);
return 0;
void konfigurasyon( unsigned char adress,unsigned char data)
unsigned int temp=0;
P1OUT &= (~BIT4); // Select Device
while (!(IFG2 & UCB0TXIFG));
UCB0TXBUF=(adress);
while (!(IFG2 & UCB0RXIFG)); // USCI_B0 RX Received?
temp = (unsigned int) UCB0RXBUF;
UCB0TXBUF=(data);
P1OUT |= (BIT4); // Unselect Device
unsigned int write_reg(unsigned char adress)
unsigned int read_reg=0x00;
UCB0TXBUF=(0x80 | adress);
read_reg = (unsigned int) UCB0RXBUF;
return read_reg;
