Hello all,
I have been spending A LOT of time trying to get this tilt adjusted compass going, i have been changing over RyanTM’s code so it can compile on MikroC.
I have got the magnetometer working what seems to be 100%, it generally gives a heading ±2 degrees. I have also implemented all of the maths for the tilt adjustment and checked all the calcs in spreasheet.
But where i am having issues is with the accelerometer. It reads the registers but the data doesnt seem to make sense to me.
Attached is the image of the raw data outputted every 1 second through serial.
I would of expected the output to be around 0 for 2 axis and ± 1g for the other direction.
I have CTRL_REG1_A set to 27 currently.
I have tried adjusting CTRL_REG4_A aswell to ±8g, and tried averaging 20 times over 1 second to see if it changed much but with no luck.
Below is my reading in code.
void I2C_read_Accelerometer(void)
I2C_Start(); delay_ms(1); //send START
I2C_Wr(0x30); delay_ms(2); //Write device address to bus for Write mode ACCEL_ADDR from Arduino ex
I2C_Wr(0x28); delay_ms(2); //Write desired address bits x axis MSB
I2C_Repeated_start(); delay_ms(1); //send repeated start
I2C_Wr(0x31); delay_ms(2); //Write device address to bus for Read mode taken from MikroC I2C example
ACC_data[0]=I2C1_Rd(0); delay_ms(1); //Read in data from register
// ACC_data[1]=I2C1_Rd(0); delay_ms(1); //Read in data from register
// ACC_data[2]=I2C1_Rd(0); delay_ms(1); //Read in data from register
// ACC_data[3]=I2C1_Rd(0); delay_ms(1); //Read in data from register
// ACC_data[4]=I2C1_Rd(0); delay_ms(1); //Read in data from register
// ACC_data[5]=I2C1_Rd(0); delay_ms(1); //Read in data from register
I2C_Stop(); delay_ms(5); //send STOP
I2C_Wr(0x29); delay_ms(2); //Write desired address bits x axis LSB
I2C_Wr(0x2A); delay_ms(2); //Write desired address bits y axis MSB
I2C_Wr(0x2B); delay_ms(2); //Write desired address bits y axis LSB
I2C_Wr(0x2C); delay_ms(2); //Write desired address bits z axis MSB
I2C_Wr(0x2D); delay_ms(2); //Write desired address bits z axis LSB
// early debug
testa=ACC_data[0];
testb=ACC_data[1];
setTX();
Usart_Write(testa);
delay_ms(1);
Usart_Write(testb);
delay_ms(1);
setRX();
Ax_raw = (int)(((ACC_Data[0] << 8) + ACC_Data[1])>>4);
if (Ax_raw > 2047) {Ax_raw = ((Ax_raw-2048)+1)*-1;}
Ay_raw = (int)(((ACC_Data[2] << 8) + ACC_Data[3])>>4);
if (Ay_raw > 2047) {Ay_raw = ((Ay_raw-2048)+1)*-1;}
Az_raw = (int)(((ACC_Data[4] << 8) + ACC_Data[5])>>4);
if (Az_raw > 2047) {Az_raw = ((Az_raw-2048)+1)*-1;}
I was hoping someone might be able to offer some insight.
Thankyou
