i’m green to the language and i’m trying to see if there is such a thing as a command to have random sequences play per button press. if anyone can help it would be much appreciated
Unfortunately, the Maestro does not have a random command. However, you might be able to use the GET_MS
and MOD
commands together to get a random number within a certain range, which is probably the easiest method to implement.
By the way, someone else on our forum had a similar question; you can see our response here for other alternatives on generating random numbers using the Maestro scripting language.
- Amanda
