Hello @PatrickM,
Do you happen to know the longest cable length that can be used between an Arduino Board and the VL53L5CX sensor? At 3.3 V and at 5 V?
Thank you!
Hello @PatrickM,
Thank you!
We have not tested the maximum wire length, but we expect it to be on the order of a few feet, and there are probably many setup-specific factors that would come into play.
In general, I2C is intended for short distances; how long are you needing the wires to be? You might consider setting up a test at that length and looking at the signals with your scope at the end of the wires to see how they are being affected.
