Hello everyone,
I’m new, and joined because I need help with controlling a linear actuator. The actuator is actually going to be used on my truck to control the position of the vanes on a variable geometry turbo. This exact setup has been used, but it only is wired to a momentary switch, so it isn’t precise and is difficult to get in the same position everytime.
The actuator isn’t directly controlling to turbo, but is just acting as a stop, or travel limiter. I esentially want to be able to wire up a 3 position switch and have each position correspond to a set point in the actuators range of motion.
Example:
2" stroke linear actuator
Switch down (or position 1) = 2"
Switch middle (or position 2) = 1.5"
Switch up (or position 3) = 1"
I’m not stuck on those values obviously or the exact switch setup, but would ideally like 3 set positions I can switch to. I am currently using this actuator on a momentary switch:
https://www.surpluscenter.com/item.asp?item=5-1554&catname=electric
12 VDC LINEAR ACTUATOR
New takeoffs VALEO model 24021541 linear actuator originally made for use in electric automotive seats. No clutch or limit switches. Permanent magnet type motor. Threaded output shaft has 13/16" x 1-3/16" x 13/16" steel block with 3/8"-18 tapped hole in side.
SPECIFICATIONSVoltage 12 VDC
Amps 1.5 no load
Travel 15/16"
Extension time 3 seconds full travel
Rotation reversible
Enclosure Fully enclosed
Duty Intermittant
Mount 1/4" dia. pin hole at base end
Shaft 7/16" dia. 8 T.P.I threaded rod
Overall size 5-1/2" x 2-3/8" x 4-3/4"
Shpg. 4 lbs.
Thanks for all of your time, I would really love it if I can make this work. I’m interested in learning from all of you, as electronics are definatly my weak point.
