I made a line follower using Arduino nano,qtr-8rc ,tb6612fng,micro gear motor and 7.2v battery i tried to upload a code ;the bot is working (motor are spinning in right direction) but it is not following the line just running here and there randomly i have been trying to fix this thing from past 3-4 days and didn’t find any thing and now i m very frustrated so please someone help me one thing i noticed when i tried to upload any other code is that once calibration is done then the motor starts to glitch (1sec moving forward and another sec moving backward) and then one motor starts to spin in opposite direction with respect to other motor and after a 1 both motor starts to move in correct order (moving forward but still doesn’t follow line)
#include<QTRSensors.h>
#define Kp 0.1 // experiment to determine this, start by something small that just makes your bot follow the line at a slow speed
#define Kd 4// experiment to determine this, slowly increase the speeds and adjust this value. ( Note: Kp < Kd)
#define MaxSpeed 255// max speed of the robot
#define BaseSpeed 255 // this is the speed at which the motors should spin when the robot is perfectly on the line
#define NUM_SENSORS 8 // number of sensors used
#define speedturn 180
#define rightMotor1 A2
#define rightMotor2 A1
#define rightMotorPWM 11
#define leftMotor1 A4
#define leftMotor2 A5
#define leftMotorPWM 10
#define motorPower A3
QTRSensorsRC qtrrc((unsigned char[]) {2,3,4,5,6,7,8,9} ,NUM_SENSORS, 2500, QTR_NO_EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
void setup()
pinMode(rightMotor1, OUTPUT);
pinMode(rightMotor2, OUTPUT);
pinMode(rightMotorPWM, OUTPUT);
pinMode(leftMotor1, OUTPUT);
pinMode(leftMotor2, OUTPUT);
pinMode(leftMotorPWM, OUTPUT);
pinMode(motorPower, OUTPUT);
delay(3000);
int i;
for (int i = 0; i < 100; i++) // calibrate for sometime by sliding the sensors across the line, or you may use auto-calibration instead
//comment this part out for automatic calibration
if ( i < 25 || i >= 75 ) // turn to the left and right to expose the sensors to the brightest and darkest readings that may be encountered
move(1, 70, 1);//motor derecho hacia adelante
move(0, 70, 0);//motor izquierdo hacia atras
else
move(1, 70, 0);//motor derecho hacia atras
move(0, 70, 1);//motor izquierdo hacia adelante
qtrrc.calibrate();
delay(20);
wait();
delay(3000); // wait for 2s to position the bot before entering the main loop
int lastError = 0;
unsigned int sensors[8];
int position = qtrrc.readLine(sensors);
void loop()
position = qtrrc.readLine(sensors); // get calibrated readings along with the line position, refer to the QTR Sensors Arduino Library for more details on line position.
if(position>6700){
move(1, speedturn, 1);//motor derecho hacia adelante
move(0, speedturn, 0);//motor izquierdo hacia adelante
return;
if(position<300){
move(1, speedturn, 0);//motor derecho hacia adelante
move(0, speedturn, 1);//motor izquierdo hacia adelante
return;
int error = position - 3500;
int motorSpeed = Kp * error + Kd * (error - lastError);
lastError = error;
int rightMotorSpeed = BaseSpeed + motorSpeed;
int leftMotorSpeed = BaseSpeed - motorSpeed;
if (rightMotorSpeed > MaxSpeed ) rightMotorSpeed = MaxSpeed; // prevent the motor from going beyond max speed
if (leftMotorSpeed > MaxSpeed ) leftMotorSpeed = MaxSpeed; // prevent the motor from going beyond max speed
if (rightMotorSpeed < 0)rightMotorSpeed = 0;
if (leftMotorSpeed < 0)leftMotorSpeed = 0;
move(1, rightMotorSpeed, 1);//motor derecho hacia adelante
move(0, leftMotorSpeed, 1);//motor izquierdo hacia adelante
void wait(){
digitalWrite(motorPower, LOW);
void move(int motor, int speed, int direction){
digitalWrite(motorPower, HIGH); //disable standby
boolean inPin1=HIGH;
boolean inPin2=LOW;
if(direction == 1){
inPin1 = HIGH;
inPin2 = LOW;
if(direction == 0){
inPin1 = LOW;
inPin2 = HIGH;
if(motor == 0){
digitalWrite(leftMotor1, inPin1);
digitalWrite(leftMotor2, inPin2);
analogWrite(leftMotorPWM, speed);
if(motor == 1){
digitalWrite(rightMotor1, inPin1);
digitalWrite(rightMotor2, inPin2);
analogWrite(rightMotorPWM, speed);
FBGZY3IITOW9BOV (1).ino (3.6 KB)
