Hello:
If the limit switch is hit when using the ticcmd with the velocity or position arguments does it initialize the position? or does initializing position only happen when homing?
Hello:
The “current position” variable is set as part of the homing procedure (e.g. using the --home DIR
option). It will not get set when the limit switch is triggered during normal use (e.g. after using the --position NUM
or --velocity NUM
options).
Additionally, you can set the current position to be the 0 position using --halt-and-set-position 0
