I have previously successfully compiler the LIBUSBP libraries on Orin AGX DevKit but I am struggling with a strange error at this moment (new Orin where I need to install it again):
When making the lib from source, following the instructions here: (Linux for Linux)
Unfortunately, the engineer most familiar with that software is out this week. However, the line indicated in your error message seems like it should be a simple #define preprocessor directive, so it’s strange that it’s causing a problem in the build process. Could you post the full output of the build command that produces that error? Please use the Preformatted text button (“</>”) on the forum or put 3 backticks (```) before and after the text so that its alignment is preserved, or attach the output in a file if it’s very long.
I have managed to resolve this issue in the meantime. It seems it only exists with the v1-latest repo clone and not with the 1.3.1 tag, i.e. if I clone the 1.3.1 directly everything compiles fine. Maybe something to fix by the repo admins.
