Even after reading the instructions, I find myself confused - When submitting a file for laser cutting, should I attempt to lay out the parts to fit into one of the standard layout areas, or do you prefer to arrange them yourself?
If your quantity requirements are very simple such as needing multiple copies of a part or layout, you can send a single copy of the design and specify the quantity while submitting your quote request.
If you have many unique parts and require different quantities for each design, we would prefer that you send us a file with all the required parts laid out; this helps us process and reply to quote requests faster.
- Arthur
