I’m building a robot, but I cannot find a chassis that is big enough for it. I need to fit a 15x10.5 cm board and a 7x7cm motor controller on it. Any suggestions?
Thanks so much!
Thanks so much!
Buy a piece of plywood and screw the things to that?
Buy some OpenBeam T-slot aluminum beam and some screws/plates and put one together yourself?
There are many, many, robot chassis of various sizes in the world. Generally, the bigger they are, the more expensive they are.
One option would also be for you to design something yourself and have us cut it for you.
- Ben
Check these out:
http://www.lynxmotion.com/p-577-tri-track-chassis-kit-no-electronics.aspx
http://www.lynxmotion.com/p-603-aluminum-4wd1-rover-kit.aspx
Both will easily hold your components.
I have the tracked version, its very well made, a bit pricey though.
You might also consider a Wild Thumper chassis, which we sell in 4WD and 6WD versions.
- Kevin
