I’m working on 6 LACT12P-12V-10 actuators connected in parallel connection each with a separate Jrk 21v3 motor controller. I want to control all 6 actuators at different lengths at a given time.
Following are the 2 things on which I need more information/clarity:
- I want to understand what does 25% duty cycle means. The product specs page says “one minute of continuous operation in four minutes.” Does it means I can use the actuator for 2 hours continously and then give rest for 6 hours? What is the maaximum amount of time I can run the actuator without resting and without damaging the internal circuit or causing thermal damage?
- What is the maximum allowable temperature that the actuator is allowed to reach before it damages itself? Is there any internal temperature sensor for this case?
- Is using an adruino uno board sufficient for the application?
Please suggest/comment
Thanks
