I’m fairly new at this stuff so I’m hoping it’s just something simple that I am not aware of.
I have the L3GD20 3-Axis gyro and am trying to get the example code for the Arduino Uno to work.
Whenever I run the example arduino code I’m just getting the message “Failed to autodetect gyro type!” The code compiles properly. Is there something I could do to verify the 3-axis gyro is not broken.
Thanks for posting pictures of your setup. You will need to solder the header pins to the L3GD20 board to make good electrical connections; simply resting the board on the header pins won’t ensure reliable contact.
I am sorry you are having problems reading your gyro. Are you getting the same “Failed to autodetect gyro type!” error? Could you tell me more about your setup? What are you using to read the gyro? Are you using the sample code? Could you post photos of your setup?
I am sorry you are having problems using your L3GD20 gyroscope. Could you tell me more about your setup? How are the wires connected to the header pins on the L3GD20? Do you have a common ground between your Arduino and the L3GD20 module? Could you try powering it directly from the Arduino’s 5V pin?
