Hello!
I am trying to access gyro measurements using Raspberry Pi and MinIMU-9. According to the datasheet (page 27) i see registers are read/wrote correcrly. For example CTRL_REG1:
But when i try to access measurement data (OUT_X_L) it always returns zero. As i understood examining C code here no special initialization needed if default parameters suit me fine. What’s the problem then?
Thanks for help!
In the commands you posted, you initially query CTRL_REG1 (0x20), but then you write and verify CTRL_REG4 (0x23). That means you’re not actually enabling the gyro, which is likely why you don’t see any output.
Yes, that should be all you need to do. It looks like you’re not using the right address, though: it should be 0x69, not 0x18. Sorry I didn’t notice that in your first post. I tested your commands with a Raspberry Pi and L3G4200D here using address 0x69 and they worked. (On ours, it appeared on I2C bus 0, not 1, but that might be different for newer RPis.)
