Hi ! ;
I have a L3G4200D gyro sensor and have been trying to get data from it.I use Arduino Due!! First I want to tell about my pin configuration. Because I have tried it in two different pin configuration. One of them is
VIN - 5V
GND - GND
VDD - (if we have apply 5V to Vin ,then the vdd becomes 3.3V output , so I have wired this 3.3 V from vdd to CS and SDO to use this sensor in I2C communication.)
SDA - to arduino’s SDA
SCL - to arduino’s SCL
DRDY and INT1 is empty
the other one is
VIN is empty ; GND to GND
VDD - I have wired arduino’s 3.3V output to sensor’s VDD , CS and SDO to use as I2C communication.
SDA , SCL , DRDY , INT1 remained same.
which one is correct. I use arduino’s internal pull up resistors sometimes I use external 4.7. But not sure if I have plugged the arduino’s internal pull up resistors. Do you know a way to on or off the internal pull up resistors for SDA and SCL?
with this configuration and this code : http://bildr.org/?s=l3g4200d ( at the bottom of the page )
the serial output is :
x : 3 Y : 65501 Z : 2
and then after rotate the sensor in X about 10 degrees the 3 became about 60 later drops to the 3 even the sensor remained 10 degree position.
I am using ADXL345 accelerometer sensor to use them in Quadcopter.
this is not your product but my sensor is this http://bildr.org/2011/03/adxl345-arduino/
Would you please give me an example code to run this properly?
