I am pretty new to MCU programming and using the Jrk 21v3 motor controller. I am using a HCS12 microcotrolller from freescale to send/receive messages to/from the Jrk 21v3 via a Serial Control Interface. I have the microcontroller setup to format the messages in UART 8N1; 1 low start bit, data bits 0 to 6, and a high stop bit. I am trying to setup a network with a RoboClaw motor controller and the Jrk. To do this I think I need to use the Pololu protocol.
I have been able to send commands in the compact protocol to get the Jrk to move a linear actuator to a target position, but when I try to use the Pololu protocol I get an error on the Jrk. I am sending 0xAA as the first byte, the device of the Jrk (11 or 0x0B) as the second byte, the set target command (0x40) with the lower 5 bits of the target value in the third byte, and the upper 7 bits of the target value in the fourth byte. I am not getting an error on the Jrk, but it is not moving the linear actuator either.
Here is the code I am using to send the bytes, the (!(SCI0SR1 & 0x80) is a flag that is raised when there is a byte to transmit. The byte it transmitted bitwise so this flag is lowered after the transmission is complete. SCI0DRL is the register that the bytes are written or read from.
void jrkSetTarget (unsigned int s) {
while (SCI0SR1_TDRE)
SCI0DRL = 0xAA; // send to set baud rate and initialize communications
SCI0DRL = 0x0B; // send the device number
while(SCI0SR1_TDRE) // make sure the last bit is gone
SCI0DRL = 0x40 + (s & 0x1F); // send target command and lower 5 bits of target position
SCI0DRL = ((s & 0xFE0) >> 5); // send the upper 7 bits of the target position
delays (10); // just gives a little time for the linear actuator to get to the target position
I should also mention that I know the bits are being sent because I am watching them on my oscilloscope
