Hi, I just purchased a baby O with two micro metal 210:1 motors. I am a CS major, but have never touched AVR or other microcontrollers, and am having trouble understanding the motor control. As a test, I am running a program that simply calls set_motors(255,255) in an infinite loop to run the motors.
I am encountering two issues. First, one motor is spinning ever so slightly faster than the other. Second, both motors are running at a speed much lower than their max. At first, I thought it was a power issue in that I could not supply enough current with the battery I was using. However, after testing multiple power sources, there is little change.
I am thinking that the issue may be related to the pwm control, but I simply do not have enough knowledge on the subject to say for sure.
I do not have an oscilliscope, so I have just been checking voltages at the motor using a multimeter, and am seeing around .7V on one, and .9 on the other. I am not sure if this is an inacurate reading due to pwm.
Thank you for any suggestions you may offer!
Neill
