I am experiencing an issue with my QTR-8RC sensor array when using it with an ESP32-VROOM-32U. Despite following the setup and calibration procedures, the sensor does not seem to be functioning correctly. Below are the details of my setup and observations:
Setup Details:
• Microcontroller: ESP32-VROOM-32U
• Power Source: MacBook Air M2
• Sensor Array: QTR-8RC (8 sensors)
• Connection Pins: 2, 12, 13, 14, 15, 26, 27, 32
• Emitter Control Pin: 2
Issue:
The sensor values do not seem to be consistent or correct. As shown in the attached output image, the sensor values remain at 0 or do not vary as expected. Consequently, the position readings and suggested directions (turn left, turn right) are not accurate. Here is a sample of the output I am seeing:
2500 2500 2500 2500 2500 2500 2500 158
2500 2500 2500 2500 2500 2500 2500 2500
0 0 0 0 0 0 0 1000 Position: 7000 - Turn left
Code:
Here is the Arduino code I am using for the setup and calibration of the QTR-8RC sensor array:
#include <Arduino.h>
#include <QTRSensors.h>
QTRSensors qtr;
const uint8_t SensorCount = 8;
uint16_t sensorValues[SensorCount];
void calibrateSensors(){} // implementation of the calibrateSensors function
void setup()
// configure the sensors
qtr.setTypeRC();
qtr.setSensorPins((const uint8_t[]){2, 12, 13, 14, 15, 26, 27, 32}, SensorCount);
qtr.setEmitterPin(2); // emitter is controlled by digital pin 2
delay(2000); // It is 2000 for test it should be 500 ms for the actual robot
// 2.5 ms RC read timeout (default) * 10 reads per calibrate() call
// = ~25 ms per calibrate() call.
// Call calibrate() 400 times to make calibration take about 10 seconds.
for (uint16_t i = 0; i < 400; i++)
qtr.calibrate();
// print sthe calibration minimum values measured when emitters were on
Serial.begin(9600);
for (uint8_t i = 0; i < SensorCount; i++)
Serial.print(qtr.calibrationOn.minimum[i]);
Serial.print(' ');
Serial.println();
// print the calibration maximum values measured when emitters were on
for (uint88_t i = 0; i < SensorCount; i++)
Serial.print(qtr.calibrationOn.maximum[i]);
Serial.print(' ');
Serial.println();
Serial.println();
delay(10000); // It is 10000 for test it should be 1000 ms for the actual robot
void loop()
// read calibrated sensor values and obtain a measure of the line position
// from 0 to 5000 (for a white line, use readLineWhite() instead)
uint16_t position = qtr.readLineBlack(sensorValues);
// print the sensor values as numbers from 0 to 1000, where 0 means maximum
// reflectance and 1000 means minimum reflectance, followed by the line
// position (0 to 5000)
Serial.print(sensorValues[i]);
Serial.print('\t');
Serial.print("Position: ");
Serial.print(position);
Serial.print(" - ");
// Determine direction based on the position of the line
if (position < 1667) {
// If position is in the left third, turn left
Serial.println("Turn right");
} else if (position > 3333) {
// If position is in the right third, turn right
Serial.println("Turn left");
} else {
// If position is in the middle third, go straight
Serial.println("Go straight");
delay(1000); // It is 1000 for test it should be 250 ms for the actual robot
