I am building a semi-humanoid robot and am experiencing some servo issues in the process. Hopefully someone can point me in the right direction to resolve this!
Short description
I have created a construction that allows a robot head to turn in 3 directions (pitch, yaw and roll). The construction is supported by bearings that allow the head to move freely. The construction uses 2x Feetech FT1117M servo’s for pitch and roll. The yaw axis uses a larger Feetech FS5115M servo. The robot consists mostly of 3D printed PLA parts. The FT1117M servo’s are used because they are compact enough to fit the design, as larger servo’s would make it more complex to fit (and the added torque would not be required).
FT1117M servo’s are marked with 2 red arrows in the image.
Issue
I am currently testing in a temporary situation if all servo’s work as expected using a Micro Maestro. The final solution will most likely use a different controller (PCA9685 for example). However I’m experiencing some significant jitter issues when the FT1117M servo’s are idle when using the Micro Maestro (6x). The servo’s don’t have any issue moving around and don’t seem to struggle when making a move. The moves don’t require a lot of torque, and bearings are also used to ensure smooth motion.
When the FT1117M servo’s move, they behave as expected. However, when stopping, they start humming or jittering heavily around the goal position. This happens more often around the “centered” position than the extremities. The FS5115M does not experience any of these issues and does not buzz or jitter around the goal position, even when used in combination with the two FT1117M’s on the Micro Maestro. Manually nudging the servo’s gently stops them from buzzing sometimes.
Electrical & control setup
- Turnigy 4000mAh 3S LiPo > 6V 2A Voltage regulator (Pololu S18V20F6) + 1000uF capacitor across 6V output > Micro Maestro
- Micro Maestro is also hooked up to a PC via USB (Windows 11, using Maestro Control Center 1.5.2.0)
Thanks in advance!
