I’m having issues getting my new programmer to program the Baby O (linux using AVRDUDE). Here’s what I’ve done so far and the results.
- Target has external power supply
- programmer cable properly corrected (based on other forum threads with images)
- The oddest response I haven’t been able to find any threads on is the lights on the AVR programmer, when the programmer is first plugged in the green light is solid and the red light is flashing - after a few seconds both lights shut off and do not turn on again until programmer is unplugged and plugged back in.
- dmseg output:
[21314.838247] usb 2-1: Product: Pololu USB AVR Programmer
[21314.838249] usb 2-1: Manufacturer: Pololu Corporation
[21314.838252] usb 2-1: SerialNumber: 00166418
[21314.839893] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
[21314.841029] cdc_acm 2-1:1.2: ttyACM1: USB ACM device
-lsusb output includes: Bus 002 Device 027: ID 1ffb:0081
- when I try to make program the sample
hriste@hriste-Aspire-R7-371T:~/Downloads/libpololu-avr/examples/atmega328p/simple-test$ make program
avrdude -p m328p -c avrisp2 -P /dev/ttyACM0 -U flash:w:test.hex
avrdude: ser_open(): can’t open device “/dev/ttyACM0”: Permission denied
avrdude done. Thank you.
Makefile:33: recipe for target ‘program’ failed
make: *** [program] Error 1
hriste@hriste-Aspire-R7-371T:~/Downloads/libpololu-avr/examples/atmega328p/simple-test$ sudo make program
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
- I get diffrent errors when I do and don’t use sudo (makes sense) but either way I can’t seem to get it to program and i can’t seem to find a solution.
Any help would be much appreciated - Thanks in advance
