Based on the code for the Zumo library it would seem that using Timer1 for motor control is completely optional, or did I miss something here?
#ifdef USE_20KHZ_PWM
OCR1B = speed;
#else
analogWrite(PWM_L, speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
If you can simply send a 0-255 PWM signal to the motor driver, then what is the advantage (i.e. the point) of using Timer1 in the first place?
ZumoMotors.cpp
#include "ZumoMotors.h"
#define PWM_L 10
#define PWM_R 9
#define DIR_L 8
#define DIR_R 7
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined (__AVR_ATmega32U4__)
#define USE_20KHZ_PWM
#endif
static boolean flipLeft = false;
static boolean flipRight = false;
// constructor (doesn't do anything)
ZumoMotors::ZumoMotors()
// initialize timer1 to generate the proper PWM outputs to the motor drivers
void ZumoMotors::init2()
pinMode(PWM_L, OUTPUT);
pinMode(PWM_R, OUTPUT);
pinMode(DIR_L, OUTPUT);
pinMode(DIR_R, OUTPUT);
// Timer 1 configuration
// prescaler: clockI/O / 1
// outputs enabled
// phase-correct PWM
// top of 400
// PWM frequency calculation
// 16MHz / 1 (prescaler) / 2 (phase-correct) / 400 (top) = 20kHz
TCCR1A = 0b10100000;
TCCR1B = 0b00010001;
ICR1 = 400;
#endif
// enable/disable flipping of left motor
void ZumoMotors::flipLeftMotor(boolean flip)
flipLeft = flip;
// enable/disable flipping of right motor
void ZumoMotors::flipRightMotor(boolean flip)
flipRight = flip;
// set speed for left motor; speed is a number between -400 and 400
void ZumoMotors::setLeftSpeed(int speed)
init(); // initialize if necessary
boolean reverse = 0;
if (speed < 0)
speed = -speed; // make speed a positive quantity
reverse = 1; // preserve the direction
if (speed > 400) // Max
speed = 400;
OCR1B = speed;
#else
#endif
if (reverse ^ flipLeft) // flip if speed was negative or flipLeft setting is active, but not both
digitalWrite(DIR_L, HIGH);
else
digitalWrite(DIR_L, LOW);
// set speed for right motor; speed is a number between -400 and 400
void ZumoMotors::setRightSpeed(int speed)
if (speed < 0)
speed = -speed; // Make speed a positive quantity
reverse = 1; // Preserve the direction
if (speed > 400) // Max PWM dutycycle
speed = 400;
OCR1A = speed;
#else
analogWrite(PWM_R, speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
if (reverse ^ flipRight) // flip if speed was negative or flipRight setting is active, but not both
digitalWrite(DIR_R, HIGH);
else
digitalWrite(DIR_R, LOW);
// set speed for both motors
void ZumoMotors::setSpeeds(int leftSpeed, int rightSpeed)
setLeftSpeed(leftSpeed);
setRightSpeed(rightSpeed);
