Dear Sirs!
I am using a POLOLU-2490 VL53L0X sensor
The sensor is connected to the Arduino Mega 2560. Used by IDE 1.8.7.
With this sensor, I measure the distance. Since I’m new, I have
there are a few questions. and I ask for help.
Please tell me
Where is the description of the Pololu library commands for the VL53L0X distance sensor that can be used from the Arduino IDE. It is desirable to have a clear and concise description of the commands with explanations and examples of use.
Please explain
If you use the VL53L0X library from Pololu in the Arduino IDE, will it work
commands from UM2039 User Manual Doc ID 029105
https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/6b/4e/24/90/d8/05/47/a5/DM00279088/files/DM00279088.pdf/jcr:content/translations/en.DM00279088.pdf
и Datasheet VL53L0X April 2018 Doc ID029104 Rev 2
https://www.st.com/resource/en/datasheet/vl53l0x.pdf
As shown in these documents, these commands cannot be used from the Arduino IDE?
- how to use commands from
vl53l0x-arduino/VL53L0X.cpp at master · pololu/vl53l0x-arduino · GitHub
Нужно ли использовать другую библиотеку?
Sincerely, Vladimir .
программа.doc (58.5 KB)
монитор порта для VL53L0X_cpp_021_english.bmp (4.3 MB)
