I’m working on a project that uses a pair of Wixels for remote control of another micro board, and I need to ‘io_repeat’ 11 switch positions on the ‘remote’ box wixel to the ‘microboard’ box.
The io_repeater example app uses a link from P0_0 to P2_1 so that both wixels can use the same program. Can I also program one wixel with a -[link_num] on a particular pin, and another wixel with a +[link_num] on the same pin, so that switch position state changes on the ‘input’ wixel will show up as state changes on the same pin on the ‘output’ wixel?
IOW: Can I do the following?
‘input wixel’
int32 CODE param_P0_0_link = -1;
int32 CODE param_P0_1_link = -2 ;
int32 CODE param_P0_2_link = -3;
int32 CODE param_P0_3_link = -4;
int32 CODE param_P0_4_link = -5;
int32 CODE param_P0_5_link = -6;
int32 CODE param_P1_0_link = -7;
int32 CODE param_P1_1_link = -8;
int32 CODE param_P1_2_link = -9;
int32 CODE param_P1_3_link = -10;
int32 CODE param_P1_4_link = -11;
int32 CODE param_P1_5_link = -12;
int32 CODE param_P1_6_link = -13;
int32 CODE param_P1_7_link = -14;
int32 CODE param_P2_1_link = -15; //cal button
‘output wixel’
int32 CODE param_P0_0_link = 1;
int32 CODE param_P0_1_link = 2 ;
int32 CODE param_P0_2_link = 3;
int32 CODE param_P0_3_link = 4;
int32 CODE param_P0_4_link = 5;
int32 CODE param_P0_5_link = 6;
int32 CODE param_P1_0_link = 7;
int32 CODE param_P1_1_link = 8;
int32 CODE param_P1_2_link = 9;
int32 CODE param_P1_3_link = 10;
int32 CODE param_P1_4_link = 11;
int32 CODE param_P1_5_link = 12;
int32 CODE param_P1_6_link = 13;
int32 CODE param_P1_7_link = 14;
int32 CODE param_P2_1_link = 15; //cal button
TIA,
Frank
