This is a USB Dongle unit for the XBee line of products. With the Xeebee dongle you can now plug the unit directly into your USB port. No cables needed. This unit works with all XBee modules including the Series 1 and Series 2.5, standard and Pro version. You can now let your PC participate in an XBee Mesh network, let your PC talk directly to your Arduino boards fitted with Xbee shields, or you can use 2 XeeBee dongles to set up a wireless serial connection between 2 PCs. This is the XBee USB adapter board only. The XBee modules themselves are being sold by other suppliers.
Features:
Carrier supports both XB24 and XBP24 modules
XBee Firmware upgrade is supported
Plug-in socket for XBee module
Leds: Power Led, Signal Strength Led, Serial Communication Led
Power directly through USB port
Supports PC to PC Wireless Serial communication
Can be used as USB <-> RS232 converter
Features are compatible with Maxstream USB interface board
Industrial Temperature Range -40° + 80°
RoHs conform
Output voltage USB 5V and 3.3V
Maximal Total Current over USB 500 mA
