The R2Duino is a fully assembled USB STICK sized Arduino clone based on the ATmega328. It has the same functionality as the Arduino Nano 3.0, but comes in a different package. It lacks only a DC power jack, but has a standard size USB connector which fits right into the USB connector of your PC. The name R2Duino comes from the fact that this microcontroller board has 2 RELAYS, connected to pins D8 and D9.
Specifications:
Microcontroller: Atmel ATmega328
Operating Voltage (logic level): 5 V
Digital I/O Pins: 14 (of which 6 provide PWM output)
Analog Input Pins: 8
DC Current per I/O Pin: 40 mA
Flash Memory: 32 KB (of which 2 KB used by bootloader)
SRAM: 2 KB
EEPROM: 1 KB
Clock Speed: 16 MHz
Dimensions: 70 x 30 x 20mm
EXTRA: 2 relays (60V AC/DC 400mA) on pins D8 and D9, enabled/disabled by jumpers
EXTRA: Standard size USB connector
Included in the package:
4 rows of pin headers. You can solder them on the board if you need them.
R2Duino was especially designed for educational institutions.
More info at:
http://www.public-art-international.com/catalog/product_info.php/products_id/219/language/en
