Hello
I am trying to establish serial communication between a raspberry pi and 3pi+ through UART. To do this, I removed the display to free up a pair of RX TX pins. I am able to send data from the 3pi+ to the Pi but I am unable to do the reverse (receive data from the Pi).
Hardware Setup
Raspberry Pi Zero
Pololu 3pi+
5V to 3.3V logic level shifter
5V to 3.3V step down voltage regulator
RASPBERRY PI PART OF CODE
Case 1- sending data from Pi to 3pi+
I have written the following code in python
import serial
import time
data = "Hello\n"
ser = serial.Serial(
port='/dev/ttyAMA0',
baudrate=115200,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
bytesize=serial.EIGHTBITS,
timeout=1
while 1:
ser.write(data.encode('utf-8'))
time.sleep(1)
Case 2- sending data from 3pi+ to Pi
Similarly for reading from the 3pi+ (this works as intended)
import serial
import time
baudrate=115200,
timeout=1
while True:
data = ser.readline().decode('utf-8')
print(f"data received: {data}")
3PI+ PART OF CODE
The code on 3pi+ is
#include <Pololu3piPlus32U4.h>
using namespace Pololu3piPlus32U4;
char bytes[100];
void setup() {
// put your setup code here, to run once:
Serial.begin(115200);
Serial1.begin(115200);
void loop() {
// put your main code here, to run repeatedly:
Serial.print("bytes for reading: ");
Serial.println(Serial.available());
Serial1.readBytes(bytes,100);
Serial1.flush();
Serial.print("data received: "); Serial.println(bytes);
// if (Serial1.available() > 0)
// // String data = Serial1.readStringUntil("\n");
// Serial.print("data: "); Serial.println(data);
// Serial1.flush();
// delay(100);
The code is as follows on the 3pi+ (works as intended)
char data[] = "from arduino\n";
void setup() {
void loop() {
Serial1.write(data);
Serial.println("sent");
delay(50);
I am not sure if I missed something trivial here or my fundamentals are shaky. Any comment is highly appreciated!
PS-
Attaching an image for Case 1
Attaching an image for Case 2
Thanks
