I have followed the directions in the readme file for linux installation “Maestro Servo Controller Linux Software (release 150116)”. Upon attempting to run the Controller software from the command line:
sudo /home/pi/Desktop/maestro-linux/MaestroControlCenter
… the MaestroControlCenter software fails to load. I’d like a workaround or to know what I’ve done wrong. Details: In the terminal the OS’s objections are:
(cli:2757): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-can-change-accels after class was initialised
(cli:2757): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-menu-popup-delay after class was initialised
(cli:2757): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-menu-popdown-delay after class was initialised
* Assertion at mini-codegen.c:807, condition `i == sel' not met
Stacktrace:
at <unknown> <0xffffffff>
at System.Windows.Forms.TextBoxBase.Draw (System.Drawing.Graphics,System.Drawing.Rectangle) <0x000af>
at System.Windows.Forms.TextBoxBase.OnPaintInternal (System.Windows.Forms.PaintEventArgs) <0x00063>
at System.Windows.Forms.Control.WmPaint (System.Windows.Forms.Message&) <0x0017f>
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message&) <0x00223>
at System.Windows.Forms.TextBoxBase.WndProc (System.Windows.Forms.Message&) <0x0031f>
at System.Windows.Forms.TextBox.WndProc (System.Windows.Forms.Message&) <0x001db>
at System.Windows.Forms.Control/ControlWindowTarget.OnMessage (System.Windows.Forms.Message&) <0x0002b>
at System.Windows.Forms.Control/ControlNativeWindow.WndProc (System.Windows.Forms.Message&) <0x0003b>
at System.Windows.Forms.NativeWindow.WndProc (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x002a3>
at System.Windows.Forms.XplatUIX11.DispatchMessage (System.Windows.Forms.MSG&) <0x00023>
at System.Windows.Forms.XplatUI.DispatchMessage (System.Windows.Forms.MSG&) <0x0002f>
at System.Windows.Forms.Application.RunLoop (bool,System.Windows.Forms.ApplicationContext) <0x00b5f>
at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext) <0x00063>
at System.Windows.Forms.Application.Run (System.Windows.Forms.Form) <0x00033>
at Pololu.MaestroControlCenter.Program.Main () <0x0003f>
at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
Debug info from gdb:
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0x731ff430 (LWP 2761)]
[New Thread 0x732ff430 (LWP 2760)]
[New Thread 0x75b7b430 (LWP 2759)]
0x76e95aac in waitpid () from /lib/arm-linux-gnueabihf/libpthread.so.0
Id Target Id Frame
4 Thread 0x75b7b430 (LWP 2759) "cli" 0x76e93770 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
3 Thread 0x732ff430 (LWP 2760) "cli" 0x76e91504 in pthread_cond_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
2 Thread 0x731ff430 (LWP 2761) "cli" 0x76e91504 in pthread_cond_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
* 1 Thread 0x76f69000 (LWP 2757) "cli" 0x76e95aac in waitpid () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 4 (Thread 0x75b7b430 (LWP 2759)):
#0 0x76e93770 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x001fff10 in mono_sem_wait (sem=0x2f523c, alertable=1) at mono-semaphore.c:119
#2 0x0017db28 in finalizer_thread (unused=<optimized out>) at gc.c:1073
#3 0x001625b4 in start_wrapper_internal (data=0x878248) at threads.c:643
#4 start_wrapper (data=0x878248) at threads.c:688
#5 0x001f5c30 in thread_start_routine (args=0x833748) at wthreads.c:294
#6 0x00204268 in inner_start_thread (arg=0x83373c) at mono-threads-posix.c:49
#7 0x76e8cc00 in start_thread () from /lib/arm-linux-gnueabihf/libpthread.so.0
#8 0x76df9728 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
#9 0x76df9728 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 3 (Thread 0x732ff430 (LWP 2760)):
#0 0x76e91504 in pthread_cond_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x001dfa3c in _wapi_handle_timedwait_signal_handle (handle=0x415, timeout=0x0, alertable=1, poll=<optimized out>) at handles.c:1588
#2 0x001f2b5c in WaitForSingleObjectEx (handle=0x1f2b5c, timeout=3076096, alertable=1045) at wait.c:196
#3 0x00160344 in mono_wait_uninterrupted (thread=0x734dec10, multiple=3128840, numhandles=1, handles=0x732fea0c, waitall=0, ms=-1, alertable=1) at threads.c:1455
#4 0x00161ed4 in ves_icall_System_Threading_WaitHandle_WaitOne_internal (this=<optimized out>, handle=0x83cc14, ms=-1, exitContext=<optimized out>) at threads.c:1587
#5 0x73c0ff98 in ?? ()
#6 0x73c0ff98 in ?? ()
Thread 2 (Thread 0x731ff430 (LWP 2761)):
#1 0x001dfa3c in _wapi_handle_timedwait_signal_handle (handle=0x414, timeout=0x0, alertable=1, poll=<optimized out>) at handles.c:1588
#2 0x001f2b5c in WaitForSingleObjectEx (handle=0x1f2b5c, timeout=3076096, alertable=1044) at wait.c:196
#3 0x00160344 in mono_wait_uninterrupted (thread=0x734decc0, multiple=3128840, numhandles=1, handles=0x731fea0c, waitall=0, ms=-1, alertable=1) at threads.c:1455
Thread 1 (Thread 0x76f69000 (LWP 2757)):
#0 0x76e95aac in waitpid () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x000b2148 in mono_handle_native_sigsegv (signal=<optimized out>, ctx=<optimized out>) at mini-exceptions.c:2299
#2 <signal handler called>
#3 0x76d5a8dc in raise () from /lib/arm-linux-gnueabihf/libc.so.6
#4 0x76d5e65c in abort () from /lib/arm-linux-gnueabihf/libc.so.6
#5 0x000136fc in ?? ()
Cannot access memory at address 0x0
#6 0x000136fc in ?? ()
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
