Hi all,
I’m using a Pololu 2998 - TB67S128FTG to drive a Lin Engineering 4418x-0111RO stepper motor. This is being used to drive a conveyor belt, for which maximum torque is desired (to be able to move larger, heavier objects). The current limit is being set using a DAC on a microcontroller - not the potentiometer. Using an oscilloscope with a current probe that takes RMS current measurements, I found the following data (RMS Current is the Y axis, DAC Vref value is the X axis.):
With AGC disabled, and microstepping set to full steps only, I was able to achieve the highest current of 1.1A. However this is still well below the rating of the motor, the Pololu stepper driver, and the power supply being used. Torque pins are all set to their highest values, and the gain selector is set to the higher range. I’m not sure what else is causing the cut-off of current at 1.1A. If anyone has any ideas on things I could try, that would be really beneficial. Thank you!
