Hi guys.
Noob question.
I have had a poke around through the forums and the user manual but have obviously missed something.
I have taken code from the analog1 example and the button example and the motor example, deleted what I thought I didn’t need, meshed it all together in what I thought should be some sort of order and then hit the build button in AVR studio 4. not surprisingly for my first attempt there were/are many errors. Most of these do not worry me as they are easy fixed and obvious mistakes. however there are some at the top of the list of errors that make me think that I am failing to access the correct (any)libraries, ie the #include lines aren’t working. (See errors below) At first I thought it may have been the way I installed the “bundle” in that I elected where I wanted the files to go. So I uninstalled everything and then reinstalled the bundle letting the installer decide where to put things. Same result. I tried using the configuration settings and linking libraries with objects. Same result. I tried in both avr-gcc and win avr. Same result. the nearest I got in the forums was a guy who was programming in c and not c++ or something like that, he was directed to section seven of the programming manual (using pololu libraries for your own projects) Where it mentioned including the “#include” lines. No help there unless I have missed something (likely). The code Is simple enough. I am trying to get an orangutan to control an linear actuator according to buttons pushed and display its position on the lcd. Its position is fed back via an attatched pot. To begin with I thought I would use the code in the “Analog” example that uses the orangutans own pot just to test the theory. Alas I have not got that far as it wont build or compile.
Code is as follows
#include "pololu/OrangutanLEDs.h"
#include "pololu/OrangutanAnalog.h"
#include "pololu/OrangutanMotors.h"
int main()
{ while(1)
// note that the following line could also be accomplished with:
// int pot = analogRead(7);
int pot = read_trimpot(); // determine the trimpot position
lcd_goto_xy(0, 0);
print("door=");
int opening = (pot-243*2)
print_long(opening),("mm); // print the trim pot position (0 - 1023)
print(" "); // overwrite any left over digits
while(1)
{ int motor direction
// wait for either the top or bottom buttons to be pressed
// store the value of the pressed button in the variable 'button'
unsigned char button = wait_for_button_press(TOP_BUTTON | BOTTOM_BUTTON);
if (button == TOP_BUTTON)
delay_ms(25);
motor direction = 512
set_motors(motor direction, 0); // runs motor forward at top speed
// turn green LED on when motors are spinning forward
if (motor direction > 0)
green_led(1);
else
motor direction = -512
set_motors(motor direction, 0); // runs motor backward at top speed
// turn red LED on when motors are spinning in reverse
if (motor direction < 0)
red_led(1);
wait_for_button_release(button)// wait for that button to be released
// all LEDs off
red_led(0);
green_led(0);
delay_ms(100);
Errors are as follows
Build started 23.3.2012 at 18:39:31
d -c ../deletethis.c
In file included from ../deletethis.c:3:
C:\Documents and Settings\ My Documents\deletethis\..\..\..\..\libpololu-avr/pololu/OrangutanLEDs.h:1:41: error: OrangutanLEDs/OrangutanLEDs.h: No such file or directory
In file included from ../deletethis.c:4:
C:\Documents and Settings\ My Documents\deletethis\..\..\..\..\libpololu-avr/pololu/OrangutanAnalog.h:1:45: error: OrangutanAnalog/OrangutanAnalog.h: No such file or directory
In file included from ../deletethis.c:5:
C:\Documents and Settings\ My Documents\deletethis\..\..\..\..\libpololu-avr/pololu/OrangutanMotors.h:1:45: error: OrangutanMotors/OrangutanMotors.h: No such file or directory
../deletethis.c:25: error: expected identifier or '(' before '{' token
../deletethis.c: In function 'main':
../deletethis.c:39: warning: implicit declaration of function 'read_trimpot'
../deletethis.c:42: warning: implicit declaration of function 'lcd_goto_xy'
../deletethis.c:43: warning: implicit declaration of function 'print'
../deletethis.c:45: error: expected ',' or ';' before 'print_long'
../deletethis.c:45:26: warning: missing terminating " character
../deletethis.c:45: error: missing terminating " character
../deletethis.c:44: warning: unused variable 'opening'
../deletethis.c:52: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'direction'
../deletethis.c:52: error: 'direction' undeclared (first use in this function)
../deletethis.c:52: error: (Each undeclared identifier is reported only once
../deletethis.c:52: error: for each function it appears in.)
../deletethis.c:56: error: expected ';' before 'unsigned'
../deletethis.c:58: error: 'button' undeclared (first use in this function)
../deletethis.c:58: error: 'TOP_BUTTON' undeclared (first use in this function)
../deletethis.c:59: warning: implicit declaration of function 'delay_ms'
../deletethis.c:60: error: 'motor' undeclared (first use in this function)
../deletethis.c:60: error: expected ';' before 'direction'
../deletethis.c:63: error: expected ')' before 'direction'
../deletethis.c:64: warning: implicit declaration of function 'green_led'
../deletethis.c:66: error: expected ';' before 'direction'
../deletethis.c:70: error: expected ')' before 'direction'
../deletethis.c:71: warning: implicit declaration of function 'red_led'
../deletethis.c:72: warning: implicit declaration of function 'wait_for_button_release'
../deletethis.c:75: error: expected ';' before 'red_led'
../deletethis.c: At top level:
../deletethis.c:83: error: expected identifier or '(' before '}' token
make: *** [deletethis.o] Error 1
Build failed with 20 errors and 9 warnings...
I’m pretty sure ive missed something that would be obvious to a headless chicken I’m just not sure what it is.
Any help would be greatly appreciated.
cheers
