This more efficient code allows passing specific parameters by reference and uses a smaller buffer. Additional data could be referenced from the buffer and returned, if desired.
void get_gps_info(float *lat,float *lon,float *utc_mo, float *utc_da, float *utc_hr, float *utc_mn){
get gps info from Parallax GPS receiver module -- coded for baby orangutan B
inputs: none
outputs: latitude,longitude,utc_month,utc_day,utc_hour,utc_minute
GPS Info: http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/GPSManualV1.1.pdf
AVR Library Command Reference: http://www.robotshop.ca/content/PDF/pololu-avr-library-command-reference-1220.pdf
Module must have clear view of sky and be level
Baby O <-> GPS <-> 7805 <-> Battery (14AH, AGM)
PD0------------sio Vin---------+12V
vin------------vin---------+5Vout
Gnd------------Gnd---------Gnd---------Gnd
PC0---LED Raw
//format of Parallax GPS GPMRC string...
//$GPMRC,HHMMSS,A,DDMM.MMMM,S,DDDMM.MMMM,S,KKK.K,HHH.H,DDMMYY,,,A*64
//012345678901234567890123456789012345678901234567890123456789012345
// 1 2 3 4 5 6
// $GPRMC string locations for following data items...
int utc_hours=7, utc_minutes=9, latitude=16, latitude_hemisphere=26, longitude=28, longitude_hemisphere=39, utc_day=53, utc_month=55;
serial_set_baud_rate(4800);
char gps[66]; // array to store $GPRMS string
char buf[1];
char type[6] = "$GPRMC";
int type_matched = 0;
int byte_count;
int i;
while(!type_matched)
do // test for valid data before continuing...
serial_receive(buf,1);
byte_count = serial_get_received_bytes();
while(byte_count == 0) byte_count = serial_get_received_bytes();
} while (buf[0] > 127); // invalid data
while (buf[0]!='$')
{ // scan forward to next $...
gps[0]=buf[0];
// is this $GPRMC?
type_matched = 1;
for (i=1;i<sizeof(type);i++)
gps[i]=buf[0];
if(type[i]!=gps[i])
type_matched = 0;
break;
if (type_matched)
// get the rest of the line...
for (i=sizeof(type);i<sizeof(gps);i++)
gps[i] = buf[0];
*lat = (gps[latitude+0]-48)*10+(gps[latitude+1]-48)+(float)((gps[latitude+2]-48)*10+(gps[latitude+3]-48))/60;
if(gps[latitude_hemisphere]=='S') *lat=-*lat; // apply sign
*lon = (gps[longitude+0]-48)*100+(gps[longitude+1]-48)*10+(gps[longitude+2]-48) \
+(float)((gps[longitude+3]-48)* 10+(gps[longitude+4]-48))/60;
if(gps[longitude_hemisphere]=='W') *lon = -*lon; // apply sign
*utc_mo = (gps[utc_month + 0]-48)*10+(gps[utc_month + 1]-48);
*utc_da = (gps[utc_day + 0]-48)*10+(gps[utc_day + 1]-48);
*utc_hr = (gps[utc_hours + 0]-48)*10+(gps[utc_hours + 1]-48);
*utc_mn = (gps[utc_minutes + 0]-48)*10+(gps[utc_minutes + 1]-48);
