I would like to confirm my plan to charge NiMh AA 220mAh 7.2V battery back (6 cells) on the IMax B6AC charger. Again, I am painfully green with this type of thing and just want to ask the experts.
Here it goes:
Connect the 4 mm banana plug to the output charge (red to +, black to -), then connect the other end to the cable to the T end of the JR connector cable with male terminator. Then connect the male terminator end of the cable to the female terminator of the pololu NiMh AA 220mAh 7.2V battery back.
Then as for the program, I would select the NimH batt, then select the NimH default program. It says 0.1 Amps ? Is this correct. (Would you recommend modifying this?) If I hit enter twice it will blink and I can modify it. I understand to hit enter again to stop the blinking. Then to get to the current limit I press inc/dec and then hit enter at the 0.6A default (or should I modify this?). How do I think start the charging? Is this automatic or do I have to load this program? A little confused by the flow chart.
How will I know the battery is fully charged?
Thanks for your support!
