Hi. I’m using VL53L1X module(Pololu - VL53L1X Time-of-Flight Distance Sensor Carrier with Voltage Regulator, 400cm Max) in my ToF system.
I’m now struggle with realizing centered optical system.
I want to be able to detect objects at different angles by reflecting the light emitted from the module with a mirror.
However, since the pololu’s module is excellent, it detects the mirror and outputs the distance to the mirror. Is there any way to successfully reduce the sensitivity or adopt the second light that comes in?
I’m using this library(vl53l1x-arduino/README.md at master · pololu/vl53l1x-arduino · GitHub) as my development environment
