CP2102 PGM02B
Driver - Hardware Ids USB\Vid_10c4&Pid_803b&Rev_0100&Mi_00&0s_NT
I assume firmware version is 1.00
I installed AVRStudio 5.1 today along with Pololu code libaries and winAVR environment on a new Windows XP SP3 notebook.
Error: The signature of the attached tool is AVRISP_2, which is unexpected.
Researching this I have found that I need to update programmer firmware which I downloaded version 1.07.
Following the directions I tried running the Configuration Utility.
When I click Start / Programs / Pololu / USB AVR Programmer Configuration Utility, I get the error message “No Pololu USB AVR Programmer was detected…” and the Start Bootloader is greyed out.
When this did not work, I have tried “shorting the bootloader pads” but the picture in the documentation is different than the hardware I have.
The closest I came was “Unreconized USB device”…
The programmer seems to be functioning as expected. Green led is on. Red led flashes until Orangutan is turned on.
What can I do?
2 hours later…
OK…I found /docs/0J6/8 Uploading firmware…
I was able to download and run “Tera Term”…
version 1.07 of the firmware would not load succussfully…
I was able to load version 1.04 of the firmware…
Does this mean I can not use AvrStudio 5.1?
Do I have to run AvrStudio 4?
What version of WinAvr should I load?
Is the pololu library the same or different?
Would it be better to upgrade the programmer?
