So… hi there im new for projects like that and i started to make it working (btw im using arduino uno and ultrasonic sensor and a motor shield l293d for this) but i couldn’t manage to make it work with the servo motor in it all works almost fine but i have a code for it in separated
This is the code without the servo motor:
const int trig = 12;
const int echo = 11;
const int leftForward = 2;
const int leftBackward = 3;
const int rightForward = 4;
const int rightBackward = 5;
int duration = 0;
int distance = 0;
void setup()
pinMode(trig , OUTPUT);
pinMode(echo , INPUT);
pinMode(leftForward , OUTPUT);
pinMode(leftBackward , OUTPUT);
pinMode(rightForward , OUTPUT);
pinMode(rightBackward , OUTPUT);
Serial.begin(9600);
void loop()
digitalWrite(trig , HIGH);
delayMicroseconds(1000);
digitalWrite(trig , LOW);
duration = pulseIn(echo , HIGH);
distance = (duration/2) / 28.5 ;
Serial.println(distance);
if ( distance < 20 )
digitalWrite(leftForward , LOW);
digitalWrite(leftBackward , HIGH);
digitalWrite(rightForward , HIGH);
digitalWrite(rightBackward , LOW);
delay(100);
else
digitalWrite(leftForward , HIGH);
digitalWrite(leftBackward , LOW);
And this is the code for only the servo:
#include <Servo.h>
Servo myservo; // create servo object to control a servo
const int trigPin = 2;
const int echoPin = 4;
void setup() {
// initialize serial communication:
Serial.begin(9600);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop() {
// and the distance result in centimeters:
long duration, cm;
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(20);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
// the condition for the distance
if ( cm > 7 && cm < 14)
myservo.write(140); // sets the servo position according to the scaled value
delay(4000);
else if ( cm < 8)
myservo.write(40); // sets the servo position according to the scaled value
delay(100);
else
delay(100);
Serial.print(cm);
Serial.print("cm");
Serial.println();
delay(100);
long microsecondsToCentimeters(long microseconds) {
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
The problem is that i can’t find a way to marge it and make it work together.
Thanks in advance.
