I’m using a D24V5Fx in a project with a raspberry pi. I want to use the SHDN function of the regulator in a low power state.
I have the project otherwise working, but I’m simply not sure what “The SHDN pin can be driven low (under 0.4 V) to turn off the output and put the board into a low-power state.” involves. Right now the pin is floating so its simply just on. Can I connect this pin to one of the Rpi GPIO pins and turn that GPIO pin on/off to sleep/wake the regulator?
Thank you for your assistance.
