I have got a baby orangutan controller and I already have an AVRISP MKII programmer. I was wondering how I should connect the programmer to the board. The pints on baby orangutan for ISP programming are not labeled. Which one is pin number 1? does Pololu use the same standard for the pin configuration of ISP? (please see the attached image)
Best,
Navid
![](https://forum.pololu.com/uploads/default/original/2X/2/21fb2e547ba3e4fb8b3dad1ae33423d621df648b.png)
Yes, the Baby Orangutan uses the standard ISP pin configuration. If you look very closely at the top side of the Baby Orangutan (around the ISP pins) you should see a small arrow. This indication arrow points to pin 1. I have attached a picture below that shows the top of the Baby Orangutan with the arrow and pin one circled in red.
-Brandon
Hello Brandon,
Thank you you very much for the reply. Solved.
Best,
Navid
