I recently bought 3 of these, in ‘partial kit’ form, from my local distributor.
I’m concerned that these may be older stock, and thus lacking the built-in power capacitor (introduced Dec 2011), to protect against LC spikes.
They’re going on projects with Dual VNH5019 boards, driving 24V motors on pwm up to 9 amps, and I’ve been seeing some electrical noise issues on my prototype, so I’d prefer to be proactive now rather than sorry later.
How can I tell if the capacitor is present ?
If its not, what type and value of capacitor should I add, to give adequate protection ?
The new revision of the 23201a board has an 0805-sized, 10 uF capacitor in series with a 1 ohm resistor, which I have highlighted in the attached picture. The original board did not have these two components (so it only had 6 components above the main chip, not 8).
If you have one of the old boards, you can connect something similar. Alternatively, you can use a higher value electrolytic capacitor and omit the resistor (since the ESR of an electrolytic capacitor should be high enough by itself).
I don’t have any SMT components, and even if I did, ‘something similar’ looks difficult on a finished, old revision board. Certainly not a wise move for a SMT ‘virgin’.
Can you suggest suitable voltage and capacitance ratings for the electrolytic option ?
I didn’t end up using these as planned last year, but they’re on my desk now, so I thought best to solder the caps on before I need them. But then I realised I’m not 100% sure; where should the caps go ? Between Vcc and GND ?
