Subject: wireless servo controller
I have an 18 channel pololu servo controller with 3 sequences programmed into it by a swiss engineer for my r2d2 dome. When I recieved the unit it has 3 cables plugged into it on 3 channels with the resistors soldered to channels 15,16,17 and to 5 volt. There are 11 servos that are programmed to do 3 sequences.
Do I require two seperate power sources or is the one with jumper ok? I tried this with about 11 volts and the servos felt like they were getting to warm.
I have a 440 mhz rf remote trigger and I am not sure how to connect the wires to be able to trigger these 3 sequences can it be done with a simple rf remote and how should I connect the pololu to the remote>?
can you help?
