How should this code be modified to make the line following robot follow a white line and black background?
#include <QTRSensors.h>
// QTRSensors
QTRSensors qtr;
// Number of sensors to use
#define IR 8
unsigned short qtrValues[IR];
#define Kp 0.1 // 255: 0.1 110: 0.2
#define Ki 0.05 // 255: 0.05 110: 0.05
#define Kd 0.003 // 255: 0.003 110: 0.004
#define rightMaxSpeed 255 // 255 50
#define leftMaxSpeed 255 // 255 50
int SetPoint = (IR - 1) * 500;
// Motor-A
int IN1 = 5;
int IN2 = 11;
// Motor-B
int IN3 = 10;
int IN4 = 6;
int lastError=0;
unsigned long cTime, pTime;
float eTime;
float P_error;
float I_error;
float D_error;
float PID_value;
void setup() {
Serial.begin(9600);
qtr.setTypeAnalog();
pinMode(4, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
qtr.setSensorPins((const uint8_t[]){21, 20, 19, 18, 17, 16, 15, 14},IR);
for (uint8_t i = 0; i < 250; i++){
if (i % 5 == 0) {
digitalWrite(4, !digitalRead(4));
digitalWrite(8, !digitalRead(8));
qtr.calibrate();
delay(20);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
digitalWrite(4, LOW);
digitalWrite(8, LOW);
for (int i = 0; i < 500; i++){
if (i % 5 == 0) {
digitalWrite(7, !digitalRead(7));
delay(20);
void run_fwd(int valueSA, int valueSB){
// Motor A
analogWrite(IN1, 0);
analogWrite(IN2, valueSA);
analogWrite(IN3, valueSB);
analogWrite(IN4, 0);
void LEDs(void){
if (abs(P_error) < 150) digitalWrite(7, HIGH);
else digitalWrite(7, LOW);
if (P_error > 130) digitalWrite(8, HIGH);
else digitalWrite(8, LOW);
if (P_error < -130) digitalWrite(4, HIGH);
else digitalWrite(4, LOW);
void Run_robot(){
char pntX[100];
char floX[10];
int med_Speed_R;
int med_Speed_L;
int position = qtr.readLineWhite(qtrValues);
P_error = position - SetPoint;
cTime = millis();
eTime = (float)(cTime - pTime) / 1000;
I_error = I_error * 2 / 3 + P_error * eTime;
D_error = (P_error - lastError) / eTime;
PID_value = Kp * P_error + Ki * I_error + Kd * D_error;
dtostrf(Kp * P_error,9,3,floX);
sprintf(pntX, "P: %s", floX);
Serial.print(pntX);
dtostrf(Ki * I_error,9,3,floX);
sprintf(pntX, " I: %s", floX);
Serial.print(pntX);
dtostrf(Kd * D_error,9,3,floX);
sprintf(pntX, " D: %s", floX);
Serial.print(pntX);
dtostrf(PID_value,9,3,floX);
sprintf(pntX, " PID: %s", floX);
Serial.println(pntX);
lastError = P_error;
pTime = cTime;
med_Speed_L = leftMaxSpeed - abs(PID_value);
med_Speed_R = rightMaxSpeed - abs(PID_value);
int leftMotorSpeed = med_Speed_L + PID_value;
int rightMotorSpeed = med_Speed_R - PID_value;
leftMotorSpeed = constrain(leftMotorSpeed, 0, leftMaxSpeed);
rightMotorSpeed = constrain(rightMotorSpeed, 0, rightMaxSpeed);
Serial.print(rightMotorSpeed);
Serial.print(" ");
Serial.println(leftMotorSpeed);
run_fwd(leftMotorSpeed, rightMotorSpeed);
delayMicroseconds(140);
void loop() {
Run_robot();
LEDs();
